Released in November 2020, the 13" MacBook Pro features Apple's Arm-based M1 SoC with both an 8-core CPU and 8-core GPU. (Model A2338 / EMC 3578 with two Thunderbolt 3 ports)
116 Questions View all
MacBook totally unresponsive after screen replacement
got the screen of my laptop replaced (before the replacement everything was working fine, just half the screen was unreadable ahah), and now after getting it back the laptop won't turn on--no sounds, touchbar, screen, anything.
I've already tried holding the power button for an absurdly long period of time and shift + control + option, and keeping it plugged in
has anyone else experienced something like this?
1 Comment:
most common mistake is to move trackpad cable aside. remove trackpad, reattach the cable, put it back. there is a thermal sensor in trackpad, if it is not readable, device will throttle cpu down to base clock rate.
by
Add a comment
1 Answer
Check your cable connections, one of them is not making the needed connection either the ZIF latch as forgotten clamping the ribbon cable or the cable was not fully inserted. You could have damaged something during the process review this guide MacBook Pro 13" Two Thunderbolt Ports Late 2020 Battery Replacement
Add a comment
Add your answer
julia k hartlep will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 39
