Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
578 Questions View all
How to replace flash drive?
I opened up my late 2015 iMac 27 inch retina and was surprised not to find a physical hard drive. My computer crapped out last week after running flawlessly since I bought it new. Ended up with the blinking folder of death. I’m thinking the factory installed 256 GB flash drive failed, how do I replace? What kit do I need? Can I also run a second SSD drive?
Add a comment
1 Answer
If your system came with a SSD then you need to follow this guide iMac Intel 27" Retina 5K Display Blade SSD Replacement
8 Comments:
Thank you, but it did not. Include an SSD or fusion drive only a flash drive.
by
Opened up and no Hard drive. I guess it only has flash?
by
@lovemyimac - A Fusion drive uses both drive ports! It’s not a single device it’s two: The SATA drive and the PCIe Blade drive.
As you stated the SATA dive was not present, that only leaves the blade drive which can be by it’s self.
by
@danj so the blade drive is what I need to replace then? Originally I ordered with a 256G drive. Can you recommend what products I need to get this computer back up and running?
by
@lovemyimac - In iMac's I always recommend pin compatible drives like the OWC Aura Pro X2 SSD as its a lot of work to go back in to dicker with the other options. I recommend going with a 1TB as the smallest.
by
Show 3 more comments
Add a comment
Add your answer
LovemyImac will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 51
