The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
control lock is dipayed
The washer is stuck on "control lock"
Score -1
Add a comment
1 Answer
Chosen Solution
Adin, here is my answer from a similar question "the normal procedure is to hold down the "end of cycle signal" (drain/spin)button for 3 to 5 seconds. The only other thing I could see is that the control interface has failed and has a stuck or shortened keypad. Or you can try to reset it by unplugging your machine, and plug it back in after 5-10 min. There is also the possibility that the interface ribbon cable became dislodged. Let us know what, if anything, work. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
Adin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 520
