Released November 2020, the PS5 console features vastly upgraded visuals and an innovative new Dualsense controller. The space-age black-and-white color scheme is a noticeable departure from PlayStation designs of the past.
192 Questions View all
PS5 rear USB-C port capacitor value
Hello,
While replacing usb-c port I knocked of capacitor near usb legs. Maybe someone knows value of it? I have no donor boards at the moment and I am not confident in my multimeter reading of 1.25-1.3 mF
Picture borrowed
3 Comments
Hi!
Not sure.. looks like a SMD ceramic capacitor. But not sure which one you need as I can't find any diagram/scheme regarding this board....
But the part came off the board right, do you still have it? Otherwise solder it back on.
The most easiest thing to do is to replace the usb board.
by
I lost it. This port is directly on motherboard, so I need a donor board for it then.
by
Hmm, That would be quiet expensive. I would try another multimeter and try again to measure it. If it's still 1.25-1.3 mF, then buy the correct smd cap and solder it on it. You could just try to see if it fixes it, otherwise you probably need a donor board for it yes...
by
Add a comment
1 Answer
Most Helpful Answer
I found the specs for it on Tronixsfix forum:
0.1uF_6.3v_0201
I hope this will be useful for a lot people out there :)
Score 1
1 Comment:
Thanks for sharing Vilius!!
Now you can buy the correct part and solder it!
by
Add a comment
Add your answer
Vilius will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 43
