2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
786 Questions View all
Dead power button fix
My 2015 MBP has a dead power button. I have determined that it is completely dead at the contact pad as if I touch it with something metal, it doesn't work. Every other key works. Is there something I can do, or does the whole keyboard need replacing?
Add a comment
1 Answer
To be clear, you are able to power on the system by shorting out the Power Pads, so it’s clearly the button that’s failed.
2 Comments:
I haven't tried that. I may have to replace the entire top case.
by
@sickminecraft45 - I would start off checking if you can bypass the keyboard first.
by
Add a comment
Add your answer
Sickminecraft45 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 66
