Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
216 Questions View all
Ipad air 2 weird charging issue
My mothers ipad air 2 stopped charging. Being 10 years old I bought the battery kit from ifixit and replaced it. Then it would charge but not if the battery got below 24%. It has to be forced into restore mode by holding home and power buttons. I found out she had been using off brand charge cable so that suggested bad tristar. So I bought a few of those and replaced it. The problems persist. The battery drops like a rock (10% every 15 minutes or so). Will not charge below 24% battery without restore mode. Only seems to charge after that if the tablet is off.
Has anyone had these issues? Could it be a faulty battery or PMIC? Im starting to worry its gonna burn her house down.
Add a comment
Most Helpful Answer
check for loose coils around the pmic
Score 1
Add a comment
Thank you for the help, I'll tear it back open this weekend and check that. I find the situation with this ipad very suspicious. This thing now has "stipulations" about charging. Changing the tristar did gain one thing, the ipad will now charge above 79%. It wouldn't be so bad if the battery would last like its supposed to.
Add a comment
Finally had time to get back to this. I cannot find any physical problems with the board anywhere. Caps, coils, battery connection...it all looks good and in place. Any other suggestions based on the symptoms? thx
Add a comment
Add your answer
idodgeads will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 48
