CPU/GPU fan replacement advice requested
In my laptop ZBook 15 G6, one of the fans starts making noise, rattles. (expected L30894-001 or L30895-001) The laptop is now almost 4 years old and this seems to be a known issue.
Does anybody have an idea how 'difficult' this exchange of both fans could be?
In terms of experience, I'm used to work with fine mechanical parts and not a total newbie in electronics. I also have an ESD bracelet and some small tools.
Thanks in advance!
Update (05/06/24)
HP Zbook 15 G6 disassembly instructions by HP can be found here: https://www.youtube.com/watch?v=7392w2ta...
I'm indecisive yet to do this myself or get help.
1 Comment
Hi Jeff,
Thanks a million for this guide and for pointing out the fan difference, this will help me a lot!
Kind regards from the Netherlands.
Frank
by
Add a comment
1 Answer
Chosen Solution
Hi @frank31876
Even better is the maintenance and service guide for the laptop.
Go to p.53 to view the procedure to remove/replace the fans.
According to the parts list on p.21 Items #14 & #15 the fan part numbers are either L68840-001 or L68841-001 depending on which GPU is installed.
Score 3
6 Comments:
Hi Jayjeff,
What puzzles me in the documentation is that the parts: L68840-001 or L68841-001 is choosing between the GPU's where the left hand side fan (14), as mentioned on page 53, is for the CPU.
Assuming the fan in the left (14) is for the CPU, and the fan at the right (15) is for the GPU. With the selection criteria provided of 2 different GPU's I'd expect 3 different numbers.
1st: CPU side
2nd & 3rd: GPU side, 2 choices
In the meantime, it will be solved a bit differently.
Since this is a company laptop, HP has been requested for a quotation.
Regards from the Netherlands,
Frank
by
@frank31876
Easiest way to know for sure is to open the laptop and check what part numbers are on the fans themselves. Usually the part numbers are printed on them
Cheers from Perth Australia
by
Today new fans were installed and the HP replacement set is: L68840-001 (label on the box)
Replacement parts, according to the labels on the fans:
CPU = Service PN: L73359-001
GPU = Service PN: L72277-001
Regarding from the low lands.
Frank
Additional:
- Part number: L73359-001 / L72277-001
According to search, fit for: HP ZBook Studio 15 G5, HP ZBook Studio 15 G6, HP ZBook 15 G5, HP ZBook 15 G6
by
@frank31876
Interesting that in the manual, they show the part number for the set of fans and not for the individual fans themselves.
Good to know.
Thanks for the feedback.
Cheers
by
@frank31876
My CPU fan in my Zbook G6 died. My NVME SSD drive temp is 83C!
I think it's the CPU fan - when the laptop is upside down with the back facing away, it's in the upper left corner and some wifi wires have to be unplugged to replace it. Do you agree that's the CPU fan?
Where did you get your fan set? I can't find it on HP's support site. Any links would be appreciated.
How difficult was it to replace the fans? Any special tricks for things like popping hidden plastic retainers loose without breaking plastic?
by
Show 1 more comment
Add a comment
Add your answer
Frank will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 21
Past 30 Days: 74
All Time: 1,334
