0.622kg (1.4 lb) tablet with a 10.8 inch display and 3 position kickstand released by Microsoft on May 5, 2015. Model number: 1645.
Surface pro screen flicker
Hi,my surface pro screen is flickering and goes blurry after about 10 minutes,it’s all updated and also done a fresh installation of windows 10 but still the same, can you please help
Add a comment
1 Answer
Most Helpful Answer
Hi @robbo1735,
Try connecting an external monitor to the laptop's mini DP port and check what happens to the display on it.
If it doesn't flicker then most likely the problem is with the screen in the laptop.
If it is determined that it is the screen, here's the ifixit Microsoft Surface 3 Display Replacement guide that may help. Take note that the repair is rated as difficult
Score 1
Add a comment
Add your answer
Robbo will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 5
Past 30 Days: 14
All Time: 236
