Apple's eighth-generation smartwatch, released on September 16, 2022.
Back Cover Replacement - Possible?
Hello. I have cracked the back of my Apple Watch 8. Is there a chance to replace it? Is it complicated? Do I have to replace the whole back or only the ring?
Thank you in advance for any help!
Add a comment
Hey Michal, Replacing the back of an Apple Watch Series 8 is generally not recommended due to the complexity and risks involved. Here's a breakdown of what to consider:
  • Repair Options:
    • If your not comfortable with fixing it yourself, some third-party repair shops might be able to replace the back. Be sure to choose a reputable shop with experience working on Apple Watches.
  • Replacement Complexity: Replacing the back is a delicate process that requires removing the display and other internal components. There's a high risk of damaging the watch if not done properly by someone with the right tools and expertise. Use the ifixit guide if necessary.
  • Replacement Parts: The back of the Apple Watch Series 8 is not designed to be easily replaced. Replacement parts, especially high-quality ones, may be difficult to find.
Recommendation:
If you bought AppleCare or are still under warranty, it's generally recommended to contact Apple Support to discuss your options (https://support.apple.com/). They may be able to offer a replacement watch or recommend an authorized service provider for repairs.
Add a comment
You want to replace the back cover with a new back cover that has the HR built in so its easier to swap out. There are mail in repair centers like JoesGE that fix Apple watches. You can also get the back covers from there as well. Here is a link for the back cover swap so you understand the process. The middle part can't just be swapped out.
https://youtu.be/jYN8KnYMdgs?si=V0_Fl0KF...
Add a comment
Add your answer
Michał Misztela will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 86
All Time: 1,227
