How to reset F29 error code on whirlpool coin operation front load was
F29 error code changed switch and still getting F29 error code. How do i reset. Coin operation machine CHW8990CW0
Hi @steve47467
Here's the tech sheet for the washer that may help.
Try entering the diagnostic service mode and check if that resets the error code - see p.4 Washer Diagnostic Mode.
If the error is still present after entering the diagnostics then check the wiring between the door lock and the CCU board is OK - see p.13 CCU Wire Harness Connector Table DLS2 and DL3 tests.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 22
