The Chromebook 13 has a carbon fiber-weave cover, magnesium-alloy wrist rest and aluminum base, making it look and feel much more high-end than typical plastic Chromebooks. The 13.3-inch screen has a full-HD 1,920x1,080 resolution, and comes in both touch and non-touch versions.
3 Questions View all
Change the ram and ssd
Add a comment
1 Answer
Most Helpful Answer
Hi @shivagaming555
Short answer is that you cannot do this as both the SSD and the ram are hard mounted on the motherboard and not easily replaceable even if you could find the compatible upgrade parts.
Here's the service manual if you want to open it up and check for yourself.
Score 1
Add a comment
Add your answer
Shivagaming 555 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 77
