Apple’s new format for the 14 lineup features a 6.7-inch OLED—like the Pro Max—but the same features as the iPhone 14 with a dual camera setup and the Bionic A15 chip with a 5-core GPU.
20 Questions View all
What might be the possible soln to this log below
See image content:
Add a comment
1 Answer
Chosen Solution
I currently have this same issue. 0x400000 is for the wireless charging coil flex. My rear cameras and flash are not working either, do yours? I have tried replacing the wireless charging coil already and it did not fix this kernel panic.
Score 1
2 Comments:
Unfortunately yes I have the same problem , no flash and no back panel. I don't know what to do to make it work . I haven't found a solution yet . I tried to put an aftermarket rear panel on it , but it was probably the panel that was faulty . Did you try to fix it with a factory part ?
by
Yes I ordered a new rear camera and wireless coil to see if either part was faulty and causing the others not to work. I also tried 2 different back panels and none of the parts fixed the issue with panic. Im starting to think that its not the camera or the wireless charging flex and actually an issue with the logic board that has disabled those circuits. I have done multiple restores even with the new parts installed and that didn't fix it so Im out of ideas.
by
Add a comment
Add your answer
Ernő Németh will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 83
