Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
117 Questions View all
Keyboard pressing other keys when only 1 key is pressed
My keyboard was fine until i upgraded my iBook. It now presses more than 1 key for certain keys for example if i type N it comes up with NM or if i type U it comes up with YU any solutions?
Score 2
2 Comments
does this happen in all programmes? I had this problem after upgrade too but only on anything using google chrome/windows compatible software, if I used safari/mac programmes I had no problem.
by
It does it even on the login menu so it is keyboard related
by
Add a comment
1 Answer
Chosen Solution
This usually happens after a short in the keyboard. I would remove and reseat the connector cable and make sure you have not left any thing in it that might short it out. To isolate the problem to just the keyboard try using an external USB keyboard and see if the problem is resolved. If all this fails then you'll need to replace the keyboard. Here's how to do that: iBook G3 12" Keyboard Replacement
Score 2
Add a comment
Add your answer
Phillip Wright will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 15
All Time: 3,739
