Repair guides, disassembly, and troubleshooting information for the Logitech VX Nano, a wireless laser mouse designed for notebook computers. Released in July 2007 and identified by model number M-RCJ134 or 910-000253.
Left Mouse Button double clicking?
Does anyone know what causes or how to fix the mouse button double clicking? It is as if when ever I am trying to either press and release or press and hold the button down that it randomly releases and presses again, making single clicks like double clicks and messing up any dragging action.
1 Comment
This issue is very common across all mouse devices. The cause is the Omron micro switch. Especially nowdays, when they are produced in china. Older Omron switches, made in Japan were much reliable. With novice soldering skills the switch can be replaced, but with enough dexterity they can be fixed by removing the cap and cleaning the contact surfaces. All versions are temporary solutions, the double click issue will return with time.
by
Add a comment
Chosen Solution
So I followed the guide on how to replace the mouse wheel just to know how to take the mouse apart. I cleaned the mouse very very thoroughly and that fixed both my sluggish mouse wheel and also my double-clicking problem! :)
1 Comment:
I had that exact problem too, and I fixed it by opening the mouse, noting the model number of the switch inside and ordering a bag of a handful of those switches, then soldering one of the new ones in. That was about five years ago and the button has yet to do anything weird again, even though the switches I bought were cheap knock-offs.
by
Add a comment
If your left mouse button double-clicking is causing issues, try adjusting the double-click speed in your mouse settings or clean the mouse to remove any debris. If the problem persists, consider updating your mouse drivers or testing a different mouse to rule out hardware failure. As a quantum expert, I recommend checking the mouse on different systems to ensure the issue is not system-specific.
Add a comment
Add your answer
Penny Stacey will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 15
Past 30 Days: 102
All Time: 738
