Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1501 Questions View all
Why is my screen stuck on the red battery charge screen?
i took my iphone apart to make a repair to the plastic cover. i put everything back together and it was working just fine, but later the same day it died and sense then the only thing that comes up on the screen is the red battery charging sign when i plug it in.
Score 9
16 Comments
i have ordered a whole new back housing for the whole iphone. it only cost $50 with shipping and it is everything but the mother board and the screen, almost a whole new phone.
by
back housing is now installed... now my screen when plugged in goes off and on from the apple symbol
by
I found the solution! For reference I have an iPhone 5, and mine went into charging screen after I tried Upgrading into iOs 9.
If you've tried every single thing on the net hard reset, soft reset, cleaning charger port, etc. and still can't get it to get OFF the Charging Screen & You think you need a new battery, TRY this method first:
Let the iPhone completely die. Plug an original iPhone charger to USB cord & into your PC or Mac. While it's plugged in - Reboot the Laptop, this may take once or several trials before the iPhone finally turns on/or into the Apple Logo, eventually you will finally be able to sign onto iTunes, and restore, or restart your iPhone. Results : Go To www.everythingicafe.com search through the forums "iphone wont charge or turn on". I bought a Battery from here, thinking that was the issue, although my phone will need a new battery eventually ( due to dying quickly ) Nothing has worked for me, Until I tried those steps. Hope this helped.
by
Thank you Emma. That worked for my iphone 3g too.
by
Thank you Emma.....was without my phone all day! Tried everything I read on the net and was just about to go to the Verizon store and saw your comment above....it took me 3 reboots but it is working now!!! Thank you!!!!
by
Show 11 more comments
Add a comment
Chosen Solution
Did you replace the battery? If so - try reinstalling the original battery. There are more poor quality batteries available than original high quality.
If the battery symbol appears with the lightening bar underneath this means that the dock connector appears to be ok but if replacing the battery doesn't work it'd be worth trying a new dock connector.
Score 3
3 Comments:
Did the battery you installed specify that it was for your model the 3GS not the 3G? They are different batteries and if it is not the correct model or if it is a low quality battery you may see these results.
by
I'm so triggered. this happened to me yesterday and I just got a girls number and its been 2 days since I saw her. please help!!
by
been there... it sucks
by
Add a comment
This iphone issue is absolute garbage. Its issues like these that make me wish that iphones weren't so popular. Basically what happens when your iphone dies is the battery disconnects a circuit to prevent the low voltage from damaging the phone or the battery in its entirety. This issue can be fixed by heating up the battery to a temp which increases the voltage enough to actually charge the phone. (not trolling.. this is such a b/s problem) What I do when (not if) this happens is, I put my phone on top of the toaster until my phone gets hot. From there I am able to actually charge the battery.
Score 3
Add a comment
There is a good chance that the housing assembly you bought has been sitting in numerous warehouses for the last several years. There is a good chance that the battery dried out.
If you got a voltmeter, you can check the voltage on the pins. Should be around 3.8 volts dc or so, with the left pin being ground. If you plug in the charger and measure, you should see the voltage going up if it is low.. If it stays the same, the battery won't hold a charge, and a replacement battery is needed...
The first thing I change on any iphone or ipod that won't turn on or charge is the battery
Score 2
1 Comment:
the cell phone is an LG. I put the battery in another LG and the battery powered up. However on my LG phone the icon appears with a red ? inside the battery & won't power on.
by
Add a comment
Hi, i also getting this problem from yesterday until now. I replaced the new battery with myself everything works fine, but the only things is the screen only show up the RED low battery mode. I've do a lot of researching. I've also replace it again with my old battery, it worked fine. But the new one stuck in red low battery mode even i charged for 8hrs or more...can someone help me to figure out how to fix it...Thanks for reading..
Score 1
Add a comment
I tried to reprogram my iphone since I accidentally reset all my settings and got stuck on the apple logo. I browsed the internet for solutions. Pressing the sleep/wake button with the home button together didn't help at all. i tried connecting it to my laptop, fonepaw iphone recovery tool was able to detect it and it said the iphone should restart to i clicked on restart, then it got back stuck with the apple logo. Now i realized the battery is empty so i had to charge it..overnight but still no effect. after charging it overnight, it got stuck with the red battery sign and apple logo wont appear anymore. what will i do? is my iphone dead? i changed the USB cable three times already and even bought a new one but it still didnt charge it. help pleas
Score 1
Add a comment
so i recently dropped my iphone 5c in water and i put in rice and worked. and it died and when i got home i charged it and it keeps showing a red logo saying its charging.
Add a comment
good evening I need help for my iphone 4s.
Its in red battery and apple logo boot looping. I tried to restore or update but nothing happens. I can open it when charging into wall but after 2-3 minutes it will die again. then I notice that modem firmware was lost, imie, signal of carrier and sounds of music. Im so desperate with this. pls some one help me.
i fixing it almost a week.
Add a comment
Maybe u should exchange battery with another same device
Add a comment
My iphone has been plugged in for 12 hours with no success. I've changed the chord, plugged it into my laptop, everything. I'm just about to order a new phone off of amazon because this one has given me so much crap with its battery. Before it did this, it would die on 90%. Ugh.
Add a comment
My Iphone 5c has been charging for 2 days. When i check on it, it shows the battery logo. I've tried hold the buttons for 20 seconds still no responds. Can someone please help me out?
Add a comment
Add your answer
Drew will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 59
All Time: 237,181
