Laptops manufactured by Dynabook (formerly Toshiba). Toshiba has since transferred 100% ownership of the laptop business to Sharp.
1289 Questions View all
Why does it freeze after the Toshiba welcome screen?
hi, i have a toshiba l300, and when i start it up after the toshiba welcome screen it freezes on a black screen with a white cursor in the left corner, will not allow me to enter bios. what can i do?
Score 4
3 Comments
it can be ram or windows issue just follow http://goo.gl/UADPvN
by
Why has my mouse pad quit working?
by
Hey guys with was the same, after hours craking my mind i try to replace the memory ram, and it works fine. i hope it help somebody. cheers
by
Add a comment
1 Answer
Chosen Solution
ian phillips, this sounds like you are having trouble with the computer finding the operating system. This could be caused by an hard drive error as well as many other things. I'd go ahead and would try this first. Important If you have not previously set a restore point in System Restore, you cannot restore your computer to a previous state. If you are not sure, or if you have not previously set a restore point, contact Support.
Restore to a point where you know your computer functioned without problems.
To start System Restore using the Command prompt, follow these steps:
Restart your computer, and then press and hold F8 during the initial startup to start your computer in safe mode with a Command prompt.
Use the arrow keys to select the Safe mode with a Command prompt option.
If you are prompted to select an operating system, use the arrow keys to select the appropriate operating system for your computer, and then press ENTER.
Log on as an administrator or with an account that has administrator credentials.
At the command prompt, type %systemroot%\system32\restore\rstrui.exe, and then press ENTER.
Follow the instructions that appear on the screen to restore your computer to a functional state.
you can also try access your BIOS to see if your hard drive still shows up in there. To get to the BIOS
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the F2 key.
2. The BIOS setup program should appear. If Windows starts, shut down the computer and try step 1 again.
Let us know what you get. Hope this helps, good luck.
Let us know if this makes a difference.
Score 3
11 Comments:
For me it just freezes then restarts
by
@tk4798 you have not given us a lot of information here. Remember that the L300 and A300 series were having issues with a bad capacitor which would cause the laptop to freeze and then reboot.....
by
It would tell me my computer had failed to start and when I press start windows normally it would go to the starting windows screen won't load and then restart
by
@tk4798 that sounds like a Windows issue, not a hardware issue. Consider reinstalling your OS
by
How do I do that
And if I have to log in it won't let me
by
Show 6 more comments
Add a comment
Add your answer
ian phillips will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 38,694
