Released in November 2017, the Oppo F5 is the first smartphone to use an 18:9 display instead of 16:9. In spite of having a 6.0-inch screen, the F5's width is similar to the 5.5" display with 16:9. Models CPH1723 and CPH1727.
How to fix the booting loop?
i just reset my phone and then the screen is not changing anymore i try to use the recovery mode but it didnt work
1 Comment:
@oldturkey03 the robot got my one of the comment and I am running low now. Please have look at it. Take it back, read it (as it is for you only) and then I will delete it
by
Add a comment
Hey hi zyro, the only thing I can suggest you at this point is a hard reset.
To do a hard reset, following the given steps:
1) Shutdown your phone
2) Put it in recovery mode (I assume you know it because you saved you tried putting it in recovery mode)
3) Wipe data or just do a factory reset
4) Reboot the system
If Hard reset also does not work then it might be just software update, also try charging the battery for a while (irrespective of it showing a sign of charging or no, just put in the cable, turn on the charger and take it back off after 20mins)before attempting a hard reset.
Thank you for reading and have a gorgeous day =)
Add a comment
Well I will suggest you to checkout the following video:
https://www.youtube.com/watch?v=tHWQbbmi...
Add a comment
Add your answer
zyro will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 41
All Time: 443
