My ps4 isn’t turning on when I place the hard disk
Yesterday I replaced my PS4 slim thermal paste and when I insert the hard disk and click the button to boot it doesn’t beep. But when I remove the hard disk it turns on and even shows the error for no hard disk (CE-34335-8). So my question is what possibly went wrong and how can I fix it.
Just to note that I’ve opened many many PS4’s but never had that problem
Update (07/10/24)
Just to add that when I push the hard drive in when the ps4 is on it immediately turns off.
When you say 'hard disk' are you referring to the Disk Drive, or the Storage Hard Drive?
by Jacob Mehnert
Yes, I mean the Storage Hard Drive
by ROKSTARGAME71
Hi! Try another working harddrive to see if the PS4 will boot or not.
If not, then it's having a short causing it to shut down. Check the motherboard especially near the SATA connector to see if nothing is shorting there..
by koppie007
@dan0 Okay bro, thanks a lot
by ROKSTARGAME71
My pleasure! Good luck with the repair!
by koppie007
