Model A1106 / 1280x854 screen resolution
90 Questions View all
Replaced DC-I. it worked for a couple days. Then Died. Why?
I replaced my DC-I board. It worked for a couple days and seems to have died. I'm wondering if my after market,(not from you), battery could have killed it, or if you have any ideas What might have. I'm back to only getting an orange/yellow light on the power chord.
Could it have been a faulty, (from You) DC-I board?
I hope I'm calling it the right thing it's the board that the power plugs into.
Oh and by the way the inside of my mac was a little different than yours on the how to guide. I'll send you a pick if it will help, but right now it's in one piece and I thought I'd leave it that way till I have a plan...
Score 1
6 Comments
What part number did you order and what are the last three figures of your serial number?
by
I ordered part #IF 154-073-1
G4 Aluminum 15" 1.5/1.67 GHz DC & Sound Card
the last three figures of my serial # are SB7
by
Hi Mayer and thanks for jumping in. I just read on another Post where it was a good Idea to unplug and leave that Bat out for 24 hrs and try it again. Since I'd had mine that way for days I tried reintroducing the battery and connecting the charger and Now (Amazingly) it's on.
With that added info can you tell me what's going on with this aging gem.
by
Thank you Mayer. I would love to if I could get it to boot up again. I'm just getting the orange light on the chord and no charge. I had some luck before disconnecting the disc drive previously so I'll try that again. Thank you! I'll let you know. JohnZ
by
Apple PowerBook G4 1.67 15" (Al) Specs
Identifiers: 15-Inch 1.67/1.5 - M9677LL/A - PowerBook5,6 - A1106 - 2029
by
Show 1 more comment
Add a comment
1 Answer
Chosen Solution
Sorry, I missed getting back to you. I've had varying luck with aftermarket batteries. Some have only lasted four cycles. Download and run Coconut battery on both the old and the new batteries. Use this older version that will run on your machine: http://www.coconut-flavour.com/coconutba...
Let us know your results. FYI - most of us that answer questions do not work for iFixit, we're just volunteers trying to help others.
Score 3
2 Comments:
Frankly, I'd return the part
by
Use a multimeter and test the output of your AC adapter. What are the test lights on your battery telling you?
by
Add a comment
Add your answer
johnzip will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 566
