error code front load washer
I have an error code on my Samsung front load washer that I cannot find the solution for this problem. Please help error code says 7r14 model number WF45H6300AW/A2
Add a comment
1 Answer
Hi,
I see what you mean, there’s no listing for 7r-14 anywhere, it simply doesn’t exist not even with Samsung.
Have you tried to reset it by unplugging and leaving off for 10 minutes and then turning it back on to see if it resolves it?
Or if another error comes up instead of the 7r-14.
Alternatively you could check the basics by cleaning inlet water filters, emptying out and cleaning the drain filter, looking for anything that might be wrapped up around moving parts.
Hope this helps
Add a comment
Add your answer
Firuz Vento will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 84
