The Lenovo ThinkPad X1 Carbon 8th Gen comprehensive repair guide is designed for students, professionals, and technicians. It provides detailed steps for troubleshooting and efficient problem-solving.
How I can change ram
i want to replace ram
and want to upgrade 8 gb to 16 gb
Add a comment
1 Answer
Most Helpful Answer
Hi @adnanhassan
The memory is hard mounted on the systemboard and cannot be replaced.
To upgrade the amount of memory you would have to replace the systemboard.
Here's the hardware maintenance manual for the laptop. Go to p.86 to view the procedure to remove/replace the systemboard.
Here's the parts lists for the MT 20U9 and 20UA models, that may help. (check for the MT number on the product information label on the bottom of the laptop).
Click on Select Commodity - System Boards (110) to find the part numbers for the 110 different systemboards that are used in the laptop. If you click on the Specs link in each part you'll see the relevant specifications of the motherboard.
Score 1
Add a comment
Add your answer
Adnan Hassan will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 90
All Time: 1,171
