Repair and support for ceiling-mounted bladed fans.
Matching up replacement capacitor
The capacitor in the top pic needs to be replaced. Can I replace it with the capacitor in the bottom pic? I know from reading other posts that the higher voltage on the red wire is fine, but I'm wondering about the configuration of the wires. The green and brown wires have the same rating in both, but are in reverse locations. The gray wires are in slightly different locations relative to the other wires too. I don't know if this matters. Thanks for your help!
Score 1
Add a comment
1 Answer
Chosen Solution
Hi Rob,
You've got good instincts here; the second capacitor will indeed substitute for the original one just fine.
And yes, when you're wiring it up, ignore the positions of the wires coming out of the device and wire it strictly according to the colors of the wires. The two grey wires are actually wired together so it doesn't matter which one goes where, as long as it's gray. For the others, stick to the original wiring colors; red to red, green to green and brown to brown (or wherever each of these is connected on the original).
Score 2
1 Comment:
Thanks very much Jerry!
by
Add a comment
Add your answer
Rob D will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 27
All Time: 509
