Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
Internal monitor Show double image
A friend of mine have this Powerbook G4 A1052 1.33.
The internal monitor now works only at 640x480 and 800x600, OS recognise it as "VGA Monitor", and the screen is "doubled", as you can see on the following image:
http://www.flickr.com/photos/77200474@N0...
On the external monitor everything works well.
I've already tried reset nvram, pram, etc (also via open firmware at boot), nothing changes. It's the monitor that needs to be changed?
Thank you
Score 1
Add a comment
1 Answer
Chosen Solution
Try starting up in Safe Mode by holding down the Shift key on startup. If this solves the problem, remove the last thing you downloaded and installed.
Score 3
Add a comment
Add your answer
Antonio Meloni will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 495
