The HP EliteBook 725 G2 is a business model released in October 2014 from the EliteBook 700 series. Built with an AMD processor and up to 16 gb of ram this device is tailored to the professional side rather than pc gaming.
My pc won't turn on
won't turn on
1 Comment:
So many possibilities, but not enough information for community to help.
by
Add a comment
1 Answer
Basically there are few steps you can try:
  1. UNPLUG the laptop power adaptor from the power jack
  2. REMOVE the laptop battery from the laptop.
  3. OPEN the back cover of the laptop, if found/can see CMOS battery, REMOVE it too.
  4. PRESS and HOLD the power button for at least 10 seconds ( for fully decharge and clear the power within the laptop)
  5. PLUG back in the power adaptor, try to POWER ON the laptop and see
If it doesnt work, then you need to find professional technician to diagnostic thru the laptop or if you got experience, you can try to dismantle the laptop and check thru is there any fault on the motherboard, connector, or any components inside.
Add a comment
Add your answer
Kumneger abay will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 153
