The Samsung Galaxy M31 is an Android smartphone which was released in march 2020. Model: SM-M315F/DSN
40 Questions View all
Why slot external memory unread the external memory card
The slot memory unread memory card data...
Add a comment
1 Answer
@raihananarco first you have to make sure that you have a working memory card. Your M32 accepts 32GB, 64GB, 128GB, 256GB and 512GB Micro SD, Micro SDHC and Micro SDXC memory cards. Also make sure it is not write protected or otherwise damaged. Check the Samsung site for more information about file formats etc. A;so, make sure that you have updated your software and that your settings are properly set.
If after all of that your card still does not read, then there is the possibility that you have issues with the card reader. Make sure that all the pins are straight and that there is no debris in the reader etc.
Add a comment
Add your answer
Raihan Anarco will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 7
Past 30 Days: 8
All Time: 18
