The Nintendo Switch is a handheld game console that can be played on the TV via a docking station, or on the go. Released March 3rd, 2017.
698 Questions View all
Nintendo switch not showing signs of life
i bought it for parts or not working , the dock flashes when i dock it , i lit it charge for 24 hours but nothing , i opened it and checked a few things :
the battery is good and is connected to main board(i checked with a multimeter)
there are no short-circuits around the IC
the usb-c has no problems connecting to the motherboard
the water damage indicator is not pink or red but white for some reason
is there a chance for short-circuits some where else ?
Add a comment
1 Answer
Most Helpful Answer
Hi!
You probably need to replace the charge IC. Please check this one first.
Please check those IC’s:
You can find them here: Nintendo Switch Teardown (step 11 and 12)
Score 2
14 Comments:
i think there are like three unsoldered pins in the BQ24193 ,should i solder them again or replace the IC ?
by
First try to solder those pins (be sure to use flux). If that failed, then try to replace it and see if that works :)!
by
i forgot to tell that i have another switch , i used its battery to test the broken switch but every thing is the same , are you sure it is the BQ24193 ?
by
Best thing is to test first! You can also check the other IC's. I know that the BQ24193 does fail sometimes.
by
even if it failed the switch should would stop charging but nothing else right ?
also can you tell me how to "check" the other IC's ?
by
Show 9 more comments
Add a comment
Add your answer
Titan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 92
