Hi @jamesw36015
Sounds like the wash pump isn't starting. Place the spray arms in a remembered position (side to side or back to front) and then turn on the dishwasher. Let it fill and then start to wash? and then open the door to stop the dishwasher (be careful, don't get wet) and check if the arms have moved from where they were positioned. It is the wash pump (circulation pump) pumping water through the spray arms that causes them to rotate.
If they haven't moved then even though you said that there is a boiling sound it could be a faulty temp sensor not indicating that the temperature is correct. Hard to know exactly, faulty sensor, faulty pump etc
Try to run the diagnostic test and check if any error codes are being displayed.
Not totally sure that the following is applicable for your model but here's the procedure to start the diagnostic tests for some Indesit dishwashers that you could try.
Switch the dishwasher on ( On/Off key).
Switch the dishwasher off ( On/Off key).
Press button “P” for 3 seconds
Switch the dishwasher on (On/Off button)
Press the Start/Pause button.
If there is an error being displayed, here's a link that may help to interpret what the error code is as shown by a combination of the LED lights (scroll down to view for LED light). The control panel for your model doesn't quite match what is shown but usually LED error codes are in a binary format counting from right to left i.e. from right to left the 4 LED lights (ignore the Push and Go LED) numerical equivalent is 1, 2, 4, 8 so depending on which LEDs are lit you just add their value i.e. the middle two of the 4 LEDs being on = 6 (2+4), one on at each end = 9 (1+8). Hopefully this makes some sense to you.
If you do get an error code that indicates what the problem may be, search online for Indesit (insert error code) to hopefully find what it means, if it isn't shown in the link above or here.
Here's a parts list (with parts layout diagrams) that may also help.
