Released September 21, 2018. Models: A1921, A2101, A2102, and A2104 / Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray (Pronounced "iPhone 10 S Max.")
376 Questions View all
will my iPhone work with 2/3 screen connectors plugged
I was replacing my battery before I accidentally ripped the bottom screen connector plug if I only use the top 2 will my phone still work?
Add a comment
1 Answer
Hi,
Unfortunately no,
You’ll either have to get the torn flex repaired or replace the whole screen.
If I understand you correctly, the ribbon you are talking about is the touch part of the screen.
If you had torn the top flex you could have just replaced the earpiece flex, but unless you transferred the chip/s from your old flex you would lose FaceID.
Hope this helps
Add a comment
Add your answer
David will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 13
