The Dell G15-5510 stands apart from the 5511 by its 10th Gen Intel 10200H processor and GeForce GTX graphics. It hosts a wider range of ports, and it built with a sleeker design without sacrificing much performance.
Alienware command center not working
How to delete cracked Alienware command center
Add a comment
1 Answer
If you need to delete or uninstall a cracked version of Alienware Command Center from your system, follow these steps carefully. Note that using cracked software can be risky and may lead to security vulnerabilities, so it’s advisable to use official versions and ensure your software is up-to-date.
Uninstall Alienware Command Center
  1. Open Control Panel:
    • Press Win + R to open the Run dialog.
    • Type control and press Enter to open the Control Panel.
  2. Navigate to Programs and Features:
    • Go to Programs > Programs and Features.
  3. Find Alienware Command Center:
    • Scroll through the list of installed programs to find Alienware Command Center.
  4. Uninstall the Program:
    • Click on Alienware Command Center to select it.
    • Click on Uninstall/Change at the top of the list.
    • Follow the on-screen instructions to complete the uninstallation process.
Remove Leftover Files and Registry Entries
  1. Delete Remaining Files:
    • Press Win + E to open File Explorer.
    • Navigate to C:\Program Files (x86) or C:\Program Files and look for any remaining folders related to Alienware Command Center. Delete these folders if they exist.
    • Check C:\ProgramData and C:\Users[Your Username]\AppData (both Local and Roaming) for any leftover Alienware Command Center files and delete them.
  2. Clean Up Registry Entries:
    • Warning: Editing the Windows Registry can cause system instability if not done correctly. Proceed with caution and consider backing up the registry first.
    • Press Win + R, type regedit, and press Enter to open the Registry Editor.
    • Use Ctrl + F to search for any entries related to Alienware Command Center. Look for keys under HKEY_LOCAL_MACHINE and HKEY_CURRENT_USER that reference Alienware Command Center and delete them.
    • You can also check HKEY_LOCAL_MACHINE\SOFTWARE and HKEY_CURRENT_USER\Software for leftover entries.
Check and Install a Fresh Copy
  1. Download Official Software:
    • Visit the official Alienware or Dell website to download the latest version of Alienware Command Center. Ensure you get the version that matches your system specifications.
  2. Install the New Software:
    • Run the installer and follow the on-screen instructions to install the official version of Alienware Command Center.
Final Steps
  • Restart Your Computer: After completing the uninstallation and cleanup, restart your computer to ensure all changes take effect.
By following these steps, you should be able to remove the cracked version of Alienware Command Center and replace it with a legitimate version. If you encounter any issues or need further assistance, let me know!
4o mini
Add a comment
Add your answer
Dhruv Bhatt will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 19
All Time: 185
