The Nintendo Switch is a handheld game console that can be played on the TV via a docking station, or on the go. Released March 3rd, 2017.
694 Questions View all
Trying to replace battery, think it might be defective
Hi ya’ll. I bought a replacement battery for my Nintendo Switch a week ago, and just took it apart yesterday. After finally removing the glue and the old one, I now can’t seem to get the connector to stay plugged in on the new one. Like it won’t stay connected.
Add a comment
Most Helpful Answer
@ivyleaguenerd possibly a bad contact or a bad connector. Take some good pictures of the board connector as well as the one on the battery. Let's see what you got going on there. Adding images to an existing question
Score 1
Add a comment
Hi!
The connector looks fine at first sight. But could still be bad. When you try to connect your original battery again, does it fit immediately? As in, does it connect without using to much pressure?
If yes, then it's probably like millimetres difference and thus the connector is bad and you should probably return the battery.
Just ask for a refund and get the battery elsewhere. Where did you bought the battery if I may ask?
Score 1
2 Comments:
Hi, yes. When I attempt to reconnect the old battery, it does stay in with just one firm push of the connector into the port. So I fear it may be the connector on the replacement battery. I got it from iFixit ironically.
by
Ahh, yeah it sounds like it indeed... I would return it and get yourself a refund.
Maybe try Amazon? https://www.amazon.com/HAC-003-Internal-...
by
Add a comment
Add your answer
ivyleaguenerd will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 7
All Time: 66
