Repairs for a broad range of sound-generating equipment including speakers, sound bars, and speaker components.
Testing output from a distance
I need a decent way to check speakers from a distance. Part of my daily test routines is to walk around a store, and try to hear the speaker 50-60 feet above my head. This doesn't always work, retail environments being what they are.
Is there a sound meter, or an attachment for an android phone that i could use to see if the speaker is broadcasting, without having to request a lift, and physically go up to the speaker? A typical retail store that I have to check has over a hundred speakers, all 50-60 feet above the ground.
Suggestions greatly appreciated!
Add a comment
1 Answer
Chosen Solution
Hi @tech043
For a quick way to find out the speaker output level at ground level where it is heard by people you can always use a mobile phone app for Apple iOS or Android. (app examples only, there are plenty of others available).
You could always use a dedicated Sound Level meter as well (examples only)
If the speakers are situated close to each other it may be difficult to determine at a distance, which one the sound is coming from however, unless you can turn them off individually somehow.
Score 2
Add a comment
Add your answer
FSE will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 103
