Repair and troubleshooting information for the HP EliteBook 840 G6, an HP laptop part of the HP EliteBook series. Released in May 2019.
19 Questions View all
Screen change for my hp
How do I change my screen
Add a comment
1 Answer
Most Helpful Answer
Hi @saitotigideon
Here's the maintenence and service guide for the laptop.
Go to p.70 (80 of 122 pdf) to view the procedure to remove/replace the display assembly.
On p.76 it shows how to remove the LCD panel from the display assembly.
Also on p.76 there are the HP part numbers for all the different LCD panels that can be used in the model.
Search online for the appropriate to your particular model LCD panel part number to find suppliers that suit you best. Usually the HP part number can be found somewhere on the back of the LCD panel itself, if you want to verify that you're ordering the correct one.
Score 1
Add a comment
Add your answer
Saitoti Gideon will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 19
All Time: 38
