The Sony Playstation 2 SCPH-790xx is the fourth revision of the Playstation2 slimline model.
15 Questions View all
Ps2 doesn’t show browser/configuration screen
Really strange one, console boots up and shows the PlayStation loader like normal, but then without a disc in it doesn’t come up with Browser/configuration, it just goes black.
Very strange, it loads games up fine and works perfectly other than this.
Help! Thanks, Luke
Add a comment
1 Answer
Hi Luke!
Is the console modded? Because it sounds like it is.
Anyway, it's possible that the modchip is broken or not configured correctly.
I can't help you with the modding part, but I recommend to remove it, if it's there.
If it's not modded at all, then it's broken on firmware level. This is very difficult to fix and basically a motherboard replacement is required....
2 Comments:
Hi mate! Thanks for the response once again!
How can I tell if it’s modded? I’m assuming you mean at hardware level, if you let me know what to look for I’ll open it up and take a look!
Thanks, Luke
by
No problem :)! Yeah at hardware level! When you open it, using this guide: PlayStation 2 Slimline Motherboard Replacement
You will probably see a chip with a LOT of cables soldered on to the motherboard. That would be the mod chip! You can share photo's with us if you are not sure! Thanks :)!
by
Add a comment
Add your answer
LukeResells will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 52
