The Nintendo Switch is a handheld game console that can be played on the TV via a docking station, or on the go. Released March 3rd, 2017.
694 Questions View all
Does the Switch Battery Replacement come with power?
Like the title says. Does it come pre charged? I plugged it in and nothing is happening.
Add a comment
1 Answer
Chosen Solution
It depends. They will usually come with some nominal amount of charge—enough to power on anyway. Or at least enough so that you would get a battery icon in the upper left corner when you connect a charger.
What was the original reason for you having replaced the battery?
Score 1
4 Comments:
Thanks for the reply! My reason was that there’s nothing on the screen, and it’s not turning on. I know it’s not the screen, and I now know it’s not the battery, as the replacement didn’t change anything.
The way it went downhill is I left Rocket League on for a few days,l on the dock. When I came back an error message appeared, then shut down permanently.
by
@gammis hm. Do you remember what the error message was? It's possible this is a board level problem. When it's in the dock, connected to the tv, do you get a green light on the docking station?
by
The green light appears for a fourth of a second, then goes off. I think the error just said “An unexpected error has occurred. Please restart console.” And then it shut off.
by
So your saying the motherboard might have gone kaput? 😬
by
Add a comment
Add your answer
GAMMI5 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 41
