2ds black screen still has black screen with power on
Hey so I got this barely used 2DS it worked like 3 months ago and I went to use it today and the screen is just black and the power is just on, no it's not on sleep mode, yes I tried the soft brick factory setting buttons. It doesn't make any noises or anything not even sounds for when you're on the home screen
Score
0
Hi there!
Is the 2DS modded? Did you tried to take out the SD card and boot it? Does the blacklight turns on? Thanks in advance!
by koppie007
The 2ds isn't modded, yea i tried to take the SD card out it's still black. And idk what the blacklight is
by Octopulus
Hmm, what you can try is to replace the wifi card! Sometimes this work. It could also be related by the camera ribbon cable. Please try replacing the wifi chip first!
by koppie007
I opened it up last night and looked inside then put it back and now it turns on and works
by Octopulus
Good to hear! So, something is starting to die or the camera ribbon cable wasn’t properly seated! Just ignore it for now, if it happens again then the next step would be replacing the camera! Have fun gaming!
by koppie007
