Hdmi connector replaced. No picture
hi,
have bought a used broken console where the hdmi port had been abused and was pressed in so the pins lost contact. i have replaced the hdmi port and capacitor but when replacing a diode got a little heat damaged on the upper plastic. how can i test that it still works? is there also a way to test that the hdmi cap is correctly soldered and has contact?
all pins on the port seem to have contact when tested, the tv senses that something is plugged in pvh the console starts with a solid white light but no picture comes. have tried starting it in safe mode. could this be because the diode is broken? or that the cap does not have sufficient contact?
1 Comment
[image|3532212]
by Nicktim
