Hi @mjrbnsn1
As @dan0 mention in his answer, your arsenal of tools will depend on what kind of jobs are you going to undertake.
I'll give you a rough example which I think is enough to start repairing most electronics.
Bench Power supply: New DC Power Supply Adjustable Linear Power Regulated Bench Switching 3005D
Soldering and re-flow station: YIHUA 852D Intelligent Air Pump Type Rework Station Soldering Station Digital
(If you buy them separately, make sure you get a soldering iron with a power rating of 75 Watts or above to be able to solder on thick boards, and make sure your heat gun (re-flow) station has a thick tube connecting the device with the heat gun handle as they have a built in fan and capapble of delivering a more consistent airflow and heat)
Microscope: TOMLOV TM4K Flex Arm Digital Microscope 4K Video LCD Microscope for Adults 64GB
(I use an AmScope Trinocular Stereo Microscope but it is too pricey to start with and these digital microscopes are really good value for money)
Multi-meter: SZ304 Multifunction 1999 Counts Digital Multimeter True RMS Handheld or Multimeter Digital LCD Voltmeter Ammeter AC DC Current Circuit Tester Autojack
(No need for a Fluke straight away, however, you want to have one that measure most basics; voltage AC/DC, capacitance, diode mode, resistance, continuity beep mode)
And you probably want to ge precision probes to measure the tiny components on the motherboards: Silicone Test Lead High-precision Measurement Multimeter Probe Pin Wire Pen
Tweezers: Titanium alloy Precision tweezers professional maintenance tool
You will also need a good quality solder (I prefer 60/40 Sn/Pb flux core leaded solder), some good quality flux (AmTech is a good choice) to make soldering easier and neater and a good solder wick (I use Gootwick 2.5mm and 1.5mm)
These are just recommendations, you can always go cheaper and more expensive, depending on your budget, but at least you know what to look for. Do your own research as well before you buy.
Hope it helps!
