How to change LCD screen
Changing the LCD screen on a Realme C15 requires patience and careful handling. Here’s a step-by-step guide:
Tools Needed:
New LCD screen for Realme C15
Plastic opening tool or spudger
Phillips screwdriver
Heat gun or hair dryer
Suction cup
Adhesive or double-sided tape
Steps to Replace LCD Screen:
1. Power Off & Remove SIM Tray
Turn off the device and remove the SIM tray using a SIM ejector tool.
2. Remove the Back Cover
Use a plastic opening tool to carefully pry open the back cover.
Be gentle, as Realme C15 has clips holding the cover in place.
3. Disconnect the Battery
Unscrew the metal cover protecting the motherboard.
Use tweezers to disconnect the battery connector to avoid a short circuit.
4. Remove the Motherboard Cover & Screws
Remove all visible screws securing the LCD screen and motherboard.
Carefully disconnect the LCD ribbon cable and touchscreen connector from the motherboard.
5. Heat & Remove the Broken Screen
Use a heat gun or hair dryer to soften the adhesive around the LCD.
Gently lift the broken LCD using a suction cup and plastic tool.
Clean any remaining glue from the frame.
6. Install the New LCD Screen
Align the new screen and connect the ribbon cable to the motherboard.
Secure it in place with adhesive or double-sided tape.
7. Reassemble the Device
Reattach all screws, reconnect the battery, and place the back cover.
Insert the SIM tray and power on the device.
Final Check:
Ensure the touchscreen and display work properly.
If the screen is unresponsive, check the connectors.
⚠️ Note: If you're unsure, it's best to take your device to a professio
nal repair shop to avoid damage. Let me know if you need help with any step!
Please be aware when referencing this answer that all indications are that it is AI-generated. While that is not necessarily bad, we do require that it be fact checked by a knowledgeable human, and we do not know if that is the case here.
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 64
All Time: 574
