Apple's top-of-the-line flagship for 2022. Released September 16th, the iPhone 14 Pro Max sports a 6.7" ProMotion OLED, the new Bionic A16 chip, a triple rear camera system, and 5G connectivity. Successor to the iPhone 13 Pro Max.
41 Questions View all
Static noise on video recording from back camera.
Hello.
My iPhone 14 pro max has a really bad video sound recording from back camera.
When I record a video with any of the back cameras the sound quality is really poor. It’s recording a real bad static noise.
Changing the settings for the video recording its not helping.
Is there a solution for this problem?
2 Comments:
Did you get the phone excessively wet? Is the display slightly pulled from the case creating a gap for water to enter?
by
No my phone is in perfect condition.
The phone is dry ,never was in contact with water.
by
Add a comment
1 Answer
Well, that only leaves the front facing microphone is part of the earpiece iPhone 14 Pro Max Earpiece Speaker if you look at the image of the part you’ll see two gasketed openings one is the earpiece speaker the other is the microphone.
It’s likely the microphone is bad. Do you still have AppleCare? If you do this would be covered under it.
Replace an earpiece speaker compatible with the iPhone 14 Pro Max model A2651, A2893, A2894, A2896, or A2895. Fix problems with phone call audio. Image
Product
$29.99
Add a comment
Add your answer
Dimitar Timev will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 18
All Time: 18
