The LG V60 ThinQ 5G, commonly referred to as the LG V60, is an Android phablet manufactured by LG Electronics as part of the LG V series. It was announced in February 2020 and is the successor to the LG V50 ThinQ. On April 5, 2021 LG announced it will be shutting down its mobile phone division and ceasing production of all remaining devices. LG noted the phone will be available until existing inventory runs out.
Right channel audio gone
The right channel audio does not work (bottom loudspeaker, right channel with wired earbuds. bluetooth is fine). I've had this issue for a while, and I decided I would replace the parts that (I thought) were defective. I replaced the bottom loudspeaker, the 3.5mm jack, and the antenna/sound board (I had also done other repairs during this such as replacing the bluetooth antenna, the battery, and the charging flex cable, all of those seem to be working fine now. It should also be noted that my flex cable replacement and the antenna/sound board replacement were ordered separately and did not arrive as one piece.) Even after doing all of that, there is still no audio coming from the right channel. I honestly don't know what to do now.
Add a comment
1 Answer
I have this problem too.
And after cleaning these two part with contact cleaner and cotton swab, both speaker and headphones works fine again.
However, after the fix, the phone can't connect to PC anymore. and charger with QC doesn't charge with full speed; it only reach full speed with PD charger. I guess I broke something during the clean.
Add a comment
Add your answer
beaviszep will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 58
