Repair and disassembly information for the second-generation iPhone SE that was announced and released in April of 2020.
256 Questions View all
iPhone se2 mic1 constant reboot
Hello users, of ifixit. Today, I want to talk about, a device, that I own, that's constantly rebooting due to mic1, I know this issue, is common, with this, specific iphone. Because there's a defect, on the logic board, where the signal, gets lost under, the sim tray. So I took some, diode readings, on the corresponding pins, responsible for the microphone. The following results are 7th pin, gave 0.259, and 8th pin gave 0.279, so I need, second opinion. What do you think, is the likelihood of this issue, the logic board, or the flex charging assembly.🤔
Update (03/04/25)
Update: I tried applying pressure, while testing, the diode readings, on the corresponding pins, for the microphone, there wasn't any significant change, or open line.
Add a comment
1 Answer
The stable but low readings, even under pressure, suggest the problem’s upstream of the flex connector. A shorted cap or corroded trace near the connector (common under the SIM tray in SE 2s) fits the pattern. Water damage or a manufacturing flaw could’ve started it.
Add a comment
Add your answer
Alkatel Pixi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 7
