Repair information and guides for the fifth generation of iPhone. Model: A1387
iPhone 4s Screw Kit?
I have replaced the screen on my sons iphone 4s, and after re-assembly, I have 1 extra screw, and NO WIFI. So after doing some reading on I see that it could be the screws in not the right places. So I am wondering where I can get the following 2 things?
1. Complete Screw Kit for iphone 4s?
2. Diagram of which screws go where?
Thanks
Score 3
Add a comment
Chosen Solution
Thanks for the reply.
I did actually find the screw kit here:
http://www.zeetron.com/iphone-4s-full-sc...
Also, was hoping for a simple printable diagram stating which size screw goes in which spot, unlike the screw mat available here.
But thanks for the reply, and once I get the screw kit I will let you know if my sons WIFI comes back on.
Thanks again!!
Score 1
Add a comment
Most Helpful Answer
Well, you're (mostly) in luck! This guide on iFixit has a step-by-step, location-based guide to what size the screws are, and where they go.
1) Other than the pentalobe screws for the bottom dock connector (which you can get here and replace with the iPhone liberation kit), it looks like the rest of the screws in the iPhone 4s are standard Phillips screws.
If you still have all your screws, though(and it sounds like you do, even if they're not all in your phone), you can compare them against the guide and see which goes where.
If you are dead set on getting a new set, it looks like you can get them from amazon here or here, though I've never used those supplier and can't speak to how good the screws are.
2) The guide I linked to above will show you what screws go where. But, if you're looking for a RIDICULOUSLY useful all-in-one solution, I personally recommend this: it's a magnetic screw mat shows you where your screws should go on your iPhone 4s, and will hold your screws in place while you reassemble your phone. It's super-awesome, and helps avoid situations where you have no idea where the screws came from :)
Replace a missing or stripped screw on the bottom of your iPhone 4 or 4S. Image
Product
iPhone 4/4S Bottom Screws
$6.99
Score 2
Add a comment
BEWARE iphone 4S has 2 socketed or standoff screws and on this site
they sell only one which means this is an iphone 4 screw set :)
Add a comment
Check out they can send you the right screws for only $7.99 shipped.
1 Comment:
irepairseattle, please refrain from placing your URL or links to your own website in the answer. This can be construed as spamming and thus violates ifixit policies.
by
Add a comment
Add your answer
Scott will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 25
All Time: 20,781
