The Lenovo IdeaPad 110-14IBR is a 15.6-inch laptop with a 500 GB hard drive 2 MB of cache memory. Produced by Lenovo, the IdeaPad is a line of consumer-oriented laptops first introduced in January 2008.
3 Questions View all
screen filled with lines
Add a comment
1 Answer
@mickey53796 you're not giving us a lot to work with here. It will help if you post some pictures of what your screen actually shows. Adding images to an existing question
Connect an external monitor to your Lenovo and see if that shows a clear picture. If so, then the issue is most likely a bad LCD screen on your computer. If an external monitor shows the same lines then the issue is with your GPU on your motherboard.
Use this Lenovo Ideapad 110 14 15 Series Hardware Maintenance Manual to work on your computer (if you do need to change the LCD assembly etc.)
Add a comment
Add your answer
Mickey will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 11
All Time: 11
