Clicks are not registering
My mouse does not register clicks sometimes I have to apply to much force for a click to register
The switches inside that make up the mouse click function can get gummed up or fail. Since I don't know which mouse you have, all I can do is give you an example of the kind of thing you might have to do to either clean the switch or replace it. Here's a video for the B100 mouse showing how to open it up and lubricate the button switches with some WD-40.
Logitech B100 Switch Fix - Disassembly (click problem) - YouTube
That could be all that's wrong with your mouse, or it could be a failing switch or even a damaged finger mechanism. No way to tell without opening it up and taking a look. Replacing a switch would require some soldering if you feel comfortable doing that, but again we'd need to know your model number before we can make concrete suggestions.
I think u r right because one time i tried to clean it by blowing air and they seem to work fine after that . Also I will work on ur solution so that it never occurs again . Thankyou :)
Past 24 Hours: 3
Past 7 Days: 28
Past 30 Days: 107
All Time: 1,069
1 Comment
Which model of mouse do you have; there are several that fall under the "B" series and it is important to know the correct one.
by Jerry Wheeler
