Screen protector is broken
My tv is working normal but it has a broken screen protector.
How do i replace it.
The cover glass is often part of the screen and not available as a separate part. It’s a fair amount of work to get the display out to even get to the cover glass. If you can get it out you might be able to measure it’s size and shape so you can get a replacement glass cut to fit from a sheet glass supplier.
But how to get the glass out is the problem.
Am I going to heat it up or what should I do?
@mohammedmutaka - Sorry can’t tell you the details of pulling the glass away from the LCD panel of your TV, often they are glued together with double sided foam tape. Just be careful around the LCD ribbon cables as you don’t want to damage them. To make the task a bit easier get this tool iMac Opening Wheel it will allow you to cut the foam tape using the wheel so you don’t go in to deep.
@mohammedmutaka - Maybe it’s best to just replace the display assembly AFB73089507 as it’s a lot easier to do
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 39
1 Comment
@mohammedmutaka there is no screen protector on an LG 55LX9500. Post an image of what your screen shows you when it is turned on. The glass is actually part of the screen and can't be replaced. There is no removal tool and from what I suspect this is, you will most likely need a new display. We will have to see this in order to make a proper determination. Let's see what you really have going on here.
Adding images to an existing question
by oldturkey03
