The iMac is Apple's line of all-in-one desktop computers.
8420 Questions View all
How do I fix the rainbow wheel for slow iMac?
My iMac is about five years old and it keep giving me the spinning rainbow wheel between screens and if I have too many things open. I have backed up most of my stuff on an external hard drive.
Score 4
Add a comment
Chosen Solution
Don't open too many things. Seriously you might try adding RAM or use the HardWare Test disk to check your HD.
If this Answer is helpful please remember to return and mark it Accepted.
Score 4
3 Comments:
Where do I find a hardware test disk?
by
@Beverly - This is a very old question and doesn't get into the different hardware systems Apple now has on the market. I would recommend you create a new question with your systems details and what you've encountering. I bet you we can get you up and running PDQ once we have the details.
by
My iMac has 32 GB RAM, it still keeps showing the wheel quite frequently - say at least once every couple of hours. I have done the hardware test and everything seems to be running fine.
by
Add a comment
Most Helpful Answer
If the spinning wheel bothers you too much and this began to happen these days, and not used to before, there are plenty of reasons for such.
Before thinking and spending bucks for upgrading any parts, look into some soft issues first.
Go to System Preferences, Users and Login Items. Remove all items from there. Restart your computer and see if that improved the spinning wheel behavior.
If not, reset your PRAM. In this case, turn off your computer, turn on, press Command, Option, P, R keys at the same time. When you hear another chime after you pressed those keys, release the keys and let it boot up normally.
If that didn't solve the issue of your spinning wheel, create a new Admin account and log in to that new Admin account and see if you observe the same spinning wheel behavior.
After attempting these soft solutions, if still the same issue persists, upgrade your RAM. That should improve speed performance slightly by decreasing the spinning wheel behavior. Enjoy!
Score 5
3 Comments:
I don’t see users and login items. I see users and groups
by
I see it now
by
Thank You following worked for me
_______________________
by
Add a comment
I cleared the login items on both accounts and the mac is way better than before, Very grateful for the advice.
Kind regards Bruno.
1 Comment:
I know this is an old question, but in case anyone is wondering about this in 2023 - this model iMac is known for it's slow internal hard drive. You could install macOS an external SSD and speed your iMac right up.
by
Add a comment
Add a comment
Add your answer
Joe will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 38,061
