Model A1199 / 2, 4, or 8 GB capacity
85 Questions View all
How do I reconnect click wheel/ jack assembly to logic board?
The repair instructions show how to disconnect the click-wheel/headphone jack assembly FROM the logic board, but do not explain how to reconnect the click wheel assembly to the logic board. Can anyone tell me how to reconnect it when you put the insides back inside the case assembly?
Score 3
Add a comment
1 Answer
Most Helpful Answer
Once you slide the motherboard back in, if it's in the right position the clickwheel/head phone jack cable should be hanging directly above where it plugs into the motherboard. You can use a small flat headed screwdriver to push the cable down into place on the board.
Score 2
1 Comment:
a tweezers or something also helps, it's tricky but just be patient and work slowly.
by
Add a comment
Add your answer
Vicky Quinn will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 12
All Time: 3,447
