The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
790 Questions View all
No Color on component cables and composite cables
when the PS3 is hooked up with component cables and composite cables it has no color we have tried many cables including brand new ones from the store. however when we hook it's up with HDMI it works fine..
Score 2
Add a comment
Chosen Solution
coreyneyrinck, make sure that you have your PS3 set to composite cables, not component cables. If you use composite cable on a composite output, you will only get black and white. You need to get composite cables (yellow, red, white) for the composite connection. You will only get color from component cables (red, blue, green, and red, white) by connecting them to component inputs. Using component cables on composite inputs, or composite cables on component inputs will give you black and white images. Also, check on here for more info. Hope this helps, good luck.
Score 1
1 Comment:
It really works
by
Add a comment
I have a ps3 but my is sanyo dosent have the thing called white hole or something is it gonna work fin?
Add a comment
Add your answer
David Johnson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 29
All Time: 89,624
