Ear Pad
3 Answers 1 Score |
Do sounds seem reversed while using the headset? |
2 Answers 0 Score |
Is your sound volume/quality low? |
1 Answer 0 Score |
Audio jack on the A40Mixamp is loose, works if I hold it down, HELP! |
1 Answer 0 Score |
Can you replace the Mic? |
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Troubleshooting
If you are having any problems, visit our troubleshooting page: Astro A40 Gen2 Troubleshooting
Background
The Astro A40 Gen2 was released on November 1, 2013 and comes with an over-the-ear headset, cables for connecting the headset to the Mixamp, and the Mixamp to the console, and a MixAmp pro. The Astro A40 Gen2 has game and voice audio balancing, customizable speaker tags, a multi-system compatibility, and can stream audio output.
In addition, the headset contains a Dolby 7.1 surround sound system that can exert frequencies from 20Hz to 21kHz, allowing you to hear everything within human hearing frequency range. The detachable microphone can exert a frequency range of 70Hz to 15kHz, meaning you will be able to talk with the highest and lowest pitch voices a human can provide.
Identification
Although the Astro A40 Gen2 headset and MixAmp Pro might seem similar to other Astro headsets, this system is the only version that is not wireless . Therefore, you can identify this device by its long wires connected to everything. Unlike the older versions of A40 Mixamps with 2 buttons, this version has 3.
