Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background Information
The CHI Original is a ceramic flat iron straightener released in 2006 by CHI, a hair-care and spa products company. Although it is a 1-inch straightener, the CHI Original can also be used to smooth, curl, wave, spiral, flip, and bend hair. It takes 30 seconds to heat up and can go up to 392 degrees Fahrenheit. Moreover, the CHI Original is dual voltage, meaning that it can accept both 110-120V and 220-240V, allowing the device to be travel friendly. The Original uses infrared technology and negative ions to make hair soft and shiny. With ceramic plates, the Original resembles a professional quality styling tool.
Technical Specifications
  • Hairtype: All Hair Types
  • Number of Pieces: 1
  • Heat Maximum: 392 Degrees Fahrenheit
  • Cable/Cord Length: 9 Feet
  • Number of Heat Settings: 1
  • Beauty Purpose: Hair Styling, Curling
  • Heating Time: 1 minutes
  • Material: Metal
  • Features: Infrared Heat, Quick Heat Up, Swivel cord, Tourmaline Coated, Ceramic Plates, Dual Voltage
  • Power Source: Electric
  • Battery: No Battery Used
  • Care & Cleaning: Spot or Wipe Clean
  • Warranty: 1 Year Limited Warranty. To obtain a copy of the manufacturer's or supplier's warranty for this item prior to purchasing the item, please call Target Guest Services at 1-800-591-3869
  • Dimensions: 10 x 1.5 x 1.5 inches
  • Weight: 1 lb
  • TCIN: 52406348
  • UPC: 633911635872
  • Item Number (DPCI): 063-09-1380
Additional Information
Amazon Reviews
CHI Product Review
Manufacturer's Device Page
Cody Trice
1 Reputation
0 Guides authored
IUPUI, Team S1-G2, Freund Fall 2017 Member of IUPUI, Team S1-G2, Freund Fall 2017
IUPUI-FREUND-F17S1G2
4 Members
3 Guides authored
Past 24 Hours: 3
Past 7 Days: 38
Past 30 Days: 178
All Time: 12,810
